Used a 2pin 250volt power cable with my Beyer A20 , caused Coil Whine(noise) ?!
Aug 18, 2016 at 12:57 PM Thread Starter Post #1 of 1
OmidelF
can someone explain this please ?
i bought a Beyerdynamic A20 amp , and one of the power cables were missing from the box (2pin cable) and since in my country power cables are all 2pins , they gave me A 2pin power cable from their shop(it was in their A2 box i think)
then i had some Coil whine issue when i played video games only , the higher the fps the higher the noise so i thought it was my GPU causing this
turns out that it was actually my power cable somehow!!!!!!!
when i used the 3pin version that was included in the A20 Box , and used a 3pin to 2pin converter , the noise was gone
so i have 2 questions
can this damage my A20 ? considering the 3pin cable is 125volt ? considering i'm using a 3pin to 2pin converter and the default power cable is 2pin in my country
and why did this happened ?
the 2pin cable was 250 volt and the 3pin cable was 125volt
