rickcr42
Are YOU talkin' to me?
- Jun 21, 2001
From the Rane Library :
Not the full story but close.They left out the part about turntable "tuning" where every single turnatable ever made to my knowledge has a self resonance point where it will peak and then fall off rapidly to each side of the peak and why we have what is called a turntable "set up" which is the balance between the tonearm/turntable/cartridge that allows the best combination of bass and tracking (so the damn cartridge does not jump right out of the groove !!!).
even a totally flat "non warped" disc will have a resonance and why the vinyl playback is called a "system" and not a "source"
**edit***
looks like benz chose a low pole and a shallow slope
http://www.dreamaudio.kiev.ua/benzmicro.htm
infrasonic filter (aka rumble filter) A high-pass filter used with phonograph turntables to reduce the effects of low frequency noise and vibration, called rumble, caused by imperfections in turntable performance and warped records. Often mistakenly called subsonic filter. Since typical rumble frequencies occur in the 3-10 Hz area, most infrasonic filters have a corner frequency of around 15 Hz, with a steep slope, or rolloff rate, of 18 dB/octave, and a Butterworth response. |
**edit***
