USB Type C 3.1 to Micro USB OTG Cable
- Thread starter hamlyn
- Getting great sounding audio.
- Q1 gets pink light (I think this means charging)
- pixel 2 battery drains SUPER fast.
I'll have to do some tinkering. Connected over usb to laptop and light was blue instead of pink. Not sure if it's because battery was full.
Hey, check out this one: https://www.ebay.com/itm/292052970340
It's shipped from Hong Kong and takes a couple of weeks but could be what you're looking for.
DarthCh0l0
This cable Mcmadface is the only one that worked on my pixel XL !!! I tried all the software tricks minus rooting and many different cable combinations to get my phone to NOT charge the DAC Battery (wasted fast)
the USB-C tip is not made of a single piece of extruded metal and instead is bent around and joined on the side. I may try to pickup a Oppo branded one as backup.
https://www.ebay.com/itm/292052970340?rmvSB=true
10cm Left Angle Micro USB to Type C Cable OTG at both ends for OPPO HA-2SE DAC
Features and Benefits:
- This Left Angle Micro USB 2.0 OTG to Type C adapter cable allows you to connect the OPPO HA-2SE portable headphone amplifier (having a micro USB port) to your Android smartphone with Type C socket.
- It has OTG setting for both ends, makes your USB-C phone NOT charging your OPPO HA-2SE DACs after connection.
- Eliminating the hassle of long cord (which required when using the common OTG cable with the female Type A socket).
- 10cm (4-inch) Long, including connectors. Lightweight for easy carrying.
- This cable is used to connect your micro USB Port of your OPPO HA-2SE DAC to the Type C socket of your smartphone.
- Compatible only with the Android Smartphones with Type C USB ports.
Darth
Darth
Ynot1
What about micro usb host OTG to usb C adapter cable? I think this is not made yet. Unless someone made it DIY.
Rufus07760
Try Meenova. I have several from them and no drain occurs.
Ynot1
https://www.amazon.com/Meenova-Mobility-Samsung-Motorola-Windows/dp/B00ZYB44UW?ref_=ast_sto_dp
I need this too, but there is no microusb otg to usb C male. I get the feeling the world wants me to upgrade my phone with a micro usb port.
Rufus07760
Have you tried audio46 in n.y.c.?
They were always helpful for me.
m-i-c-k-e-y
Fiio CL06
Ynot1
I still need the one that goes the other way for the host or otg side. The CL06 has usb C as the host or OTG and not the micro usb side as the host or OTG.
