thomaspf
- Aug 30, 2003
Here is a entry level overview of the encoding of multichannel material into S/PDIF.
The resulting payload is equivalent to a 16bit/48Khz uncompressed PCM stream with a few flags in the headers set to identify the stream type.
Most sourround receivers analyze the stream in real time and will automatically switch to surround mode independent of the header flags if they detect the samples to contain encoded sourround material. That is how the popular test for bit perfect playback works. These tracks just look like standard 2 channel PCM files to the system but the receiver switches to surround mode anyhow.
So from a USB sound card perspective all it needs to supports is 16bit/48Khz to pass through encoded sourround streams to an S/PDIF interface.
Cheers
Thomas
Cheers
Thomas
