skepticalnewb
- Feb 12, 2011
Hi!
I have a problem and maybe there are some techies here that can advise.
I got an usb/spdif converter the other day, made by a friend - so not really a brand but he's an audio techie. I am connecting it to a usb cable and the other end is plugged directly into a dac on rca spdif connector.
I tried using it through a 5 m cable but I am getting dropouts every few seconds - 5 or 10 or so, irregularly. I tried cheap cables for now, 4 of them different brands and having different specs but the result is same.
No matter if I connect my desk pc or notebook it's the same.
I tried a 1.8m cable and it worked just fine.
I thought it might be some power issue, but with the long (4.5m to 5m) cables my notebook is having same problem if running on batteries, too.
I wondered if it's a power issue, one of the cables is a Belkin pro that is supposed to have awg20 power wire inside (thickest for usb, normally it's 24 or so in other cables... thinner).
I also checked the USB device (running on default windows driver, requires no specific driver). The device is connected at 1.1 full speed so the usb specified max should be 5m of cable (if it was low speed, 3m would be max but it isn't the case).
Some of the cables are thicker or thinner than others so there's a shielding (or lack of) difference between them but doesn't seem to matter.
I know there are super expensive cables out there that makes people's jaw drop when listening to, but for now I'd rather have a dry, technical approach to the problem.
What do you think is causing the dropouts? I realise some off-spec chinese cable might behave bad but that's why I got 4 cables, I don't think none of them meet the usb specifications.
Can it be a power issue (I'm no good in physics)? Or what else?
There are a couple people using same device, one with 4m, other with 4.5m cable, they did have this problem at some point in time but switched to other cheap pc usb cable and it works now. Those are also just random cables that don't even have brand on them just the usual usb specification stuff (28awg/24awg etc.)
Appreciate any input.
ps. the device is using isochronous transfer mode, if it matters.
