barbz127
- Oct 8, 2009
Hi all,
I'm having issues where any dac connected to my PC is noisy (beeping, popping and static) which gets worse when you move the mouse (sound correlates to this).
I have tested a friends ifi galvanic which removed the noise, I purchased an ifi defender to be cheap and try to fix the noise without success.
What else exists in between these two price points that youve had positive experiences with?
I have also checked all the usual things such as grounding of desktop to earth (0.4ohm) without success. The noise is gone if I use my laptop but this isnt a permanent fix.
Desktop is a amd ryzen 1700 running on an itx board (unsure if this would have something to do with it).
Thankyou
Thankyou
