Revered48
- May 5, 2014
Hello everyone!
I am currently having issue with a buzzing noise I get from low frequency’s 10-50 hz I have and had the magni and modi plugged into all of the usb ports on my computer tower and I thought I narrowed it down to the dac but then unfortunately only to try and use the stack on my Microsoft surface and the buzz was no longer present
. So it must be my usb ports in my MOBO?
Does anyone have any idea what may cause this?
Yes I have switched out my cables and other methods of interference.
Starting at 10 hz the buzzing will happen
here is a website i use.
http://www.audiocheck.net/soundtests_headphones.php
Thank you
Z87-g43 = MOBO
Chris…
Thank you
Z87-g43 = MOBO
Chris…
