JMcMasterJ
- Jan 20, 2005
Hello, I'm having a problem with interference on my Macbook Pro and I'm not sure what to do.
I usually use my MBP connected to an external monitor. When my USB DAC is connected to the right USB port and the DVI cable is plugged in I get interference from the DVI cable. When the DVI cable is unplugged, I don't get any interference. The same is true with the left USB port and the MBP's power cable.
I tried using 3 different USB cables, one of which had ferrite cores, but they all suffered from the same problem. The one with the ferrite cores seemed to have slightly less noise. When plugged into a USB hub, I didn't notice the interference as much, but the music would stutter.
What should I do? Should I try a better shielded cable or something else?
