- Mar 20, 2011
I had compared three usb cables about a year ago and believe I posted my results on this exact thread (other wise I forget why I subscribed to it in the first place).
I compared a standard HP printer usb cable, my audioquest carbon (which I recently upgraded) and the Tellurium Q silver usb cable. I remember being impressed by the tellurium, and also guessed it on a double blind test 4 out of 6 times between my brother and friend swapping cables randomly. Now, of course that's not 6 out of 6, but I was convinced it seemed less veiled. Another weird observation I made was that the audioquest carbon sounded warmer than the stock usb cable, with more midbass presence. We're talking very minute differences, but still what I remember and noted. Also, when using the printer usb and audioquest carbon, I remember my music clipping 2-3 times per high res song (24 bit 192khz and up); whereas the tellurium q only clipped once in about an hour of listening one evening. This is what probably caused the bias in thinking that usb does make a difference; but it can also be pure coincidence.
And yes, I work in retail and I am a salesperson; but I'm one of the honest ones as I was suckered into this hobby myself
. I've always been used as a guinea pig for analyzing tracks as I have the best ears between my friends and co-workers. They don't often capture small intricate musical passages or artifacts, and I often pick them up and tell them what to listen for; it's then that they would hear them. I felt the need to try it out for myself at the time and did so. I can't say with 100% certainty if usb cables can sound different, but I am more inclined to say yes. As soon as you have different materials involved, you should expect change (not necessarily improvements).
I recently tried the audioquest diamond and ordered one as I felt it simply sounded more "correct" and transparent. The DBS system may help with noise floor as advertised, but I can't confirm. My McIntosh MC225 with the NAD M51 does seem to have less of a noise floor; but I also got new tube dampers. The HD800's on my rig do reveal a lot so there is less of a noise floor.
Still, it's so difficult to judge, that I say it's simply not worth it for most to break their heads over it. For my system and the money I put into it, I think it's very well worth it. But if you don't have a "hi-fi" system; it's not worth your time, money and paranoia.
Stay updated on Audio-Technica at their sponsor profile on Head-Fi.
