Usb c dongle dac to rival my LG G8x quad dac....
Apr 26, 2023 at 5:49 PM Post #16 of 16
Hi...listen i have the Btr5 2021 the E1DA 9038S and Hiby Fd3 which i am selling. In my experience the E1DA 9038S is a monster of quality and raw power (hip hop just BANG just with Moondrop Aria or Tin Hifi P1 plus which require POWER or better the Letshuore s12 or Tin Hifi T3 ). The Fiio on LDAC for the road is either great at unbeatable price. THEN if I were you j would consider the Earmen Sparrow (that eat the dragonfly😅....made in Europe ,very nice Dac but i had to return as it was only working on 3.5 which has powerful but not enough for the Tin P1 planar iem ).If you want save money and don't mind the questionable MQA ,get the E1DA 9038S and you will enjoy it! I have attached on the back of S10 5G with double side 3M tape and made a bumper to protect it made of elastic rubber .
If you want BT go for Fiio Btr7 also with TXT amps ...You have PLENTY choices. Instead want to buy a LG V40 Thinq....but not certain undecided. Happy buy
Hi! What is your opinion about fd3? Does it sounds good? Thx
