chuck8403
- Feb 5, 2014
I am using an iMac (mid-2011). When I have the USB hooked up to my Schiit Bitfrost or my Schiit Modi (then to my Lyr), I hear a noise that sounds like water splashing. I disconnect the USB cable and the noise goes away. The noise can very with the movement of my mouse (Logitech USB transmitter).
Once I decided to use the Optical output, the sound is great. So the problem is solved. But it is frustrating that I can't use the USB for audio. Not sure it really matters, but frustrating. Any thoughts on what is causing this? Just curious.
