ufospls2
- Dec 9, 2014
Hey All,
I've been having trouble with distortion for a while now. It doesn't happen all the time, thats why it is so maddening. At first I thought it was my dac, then I tried another dac, and it still was happening. Then I thought it was my amp, so I tried another amp and it was still happening.....but the thing is it doesn't happen all the time so it isn't my headphones. It only happens at certain frequencies, percussive noises, and low end. It gets worse if you boost the bass a bit with EQ. An example of a song that makes them distort is.
https://www.youtube.com/watch?v=PFcdXvJIfSM
The kick in the beginning distorts, sometimes. It happens with all headphones, I have tried 4 different pairs. So it is not my amp, it is not my dac, it is not my headphones, as I have tried more than one of each, so what the hell is it? I am using a mac, with Fidelia as my music software. The distortion happens with other software as well. Right now I am using a LH Labs Geek Out V2, as the distortion seems to happen less often than with my big set up. I'm not sure why. I have tried a restart of my computer, and a PRAM re set (I am using a mac.) I have tried a different usb cable. It is maddening, and I have no clue what is causing it.
I should add that it only happens at higher volumes, lower volumes there is no distortion at all.
I have tried both the USB ports on my macbook pro, and it happens with both. I feel like I have tried everything, but there is probably something small I am missing. Any ideas? Thanks for the help.
