Upgrading from Senn 280 pro: HELP MEEEEE :D
Jun 12, 2004 at 4:37 PM Thread Starter Post #1 of 3
Pirvy
Hey guys,
i ahd just bought an HD 280 pro, sound is great but the thing feels like its going to squish my head
i need a new set and i was thinking ok:
HD 580 II Precision (whats the diff between the 1 and 2?)
HD 590
or only if its really worth it HD600
Alternatively i want a nice headset for PC games, and rock/pop music with a maximum cost of EUR 200 -220 - less is better
also do you guys know of any good EU online stores for headsets?
UPDATE: I found a couple of good deals on Ebay and i foutn the HD 600 and Beyerdynamic BT880 in my pricerange.
i am looking for a set of open headphones with emphasis on rock music and comfort - somethign i can spend hours with basically
regs
Kurt
Jun 12, 2004 at 4:51 PM Post #2 of 3
well i own a pair of HD280s and just upgraded to the A900, should be here sometime next week. The HD280 pros are by no means bad, just lacking in some areas when compared to other cans.
are you looking for closed or open cans? the ones you mentioned are open, while the A900 are closed as are the HD280 pros...
