jamato8
The Mills are used for the large voltage drops as they are in the larger wattage and you want to use more wattage than needed for safety and sound reasons. The Riken are used in the smaller voltage drop areas and for the bias and .5meg ohm resistors. Actually using a wire wound inductive resistor in the power supply isn't a bad thing as they just add to the inductance and get rid of a bit of possible noise on the DC. The large value resistor is the one bolted to the internal chassis. You need to use a large wattage Mills or inductive wire wound for that 500 ohm position and if a Mills then know that suspended in air is fine as they are rated for that but some resistors that are suspended that were meant to be mounted have to be derated if not mounted. Either the Mills or an inductive resistor is fine.
