DJGeorgeT
- Mar 5, 2004
You pointed out your own problem. Grado has 'its' sound. You can't expect other headphones to sound gradolike, yet they may still provide great sound. At $200 the E4C does sound great, it is comfortable to wear, provides great isolation and it is very small. It sure is worth the $200. It just doesn't sound the way you want it to sound, so you don't think it is worth $200.
Originally Posted by Mr.Shadow (I am used to Grado SR-80 so it is kind of reasonble it will happen). since it is my first IEM phone i dont know what to say, but I think that for 200$ it simply dosent deliver the sound I would Expect from a 200$ Phone. I mostly Listen to metal, and the guitars in the E4c sounds laidback, It lacks the Detail I use from the SR-80, The bass is great, Tight, Punchy and has a pleasureable amount. Am I living on the moon or am I not alone ? |
