Understanding the Role of DACs in a Simple Audio Setup
Dec 1, 2024 at 6:03 AM Post #91 of 182
Except…
Math has infinite points along the edge of the circle, technology does not.
The DAC is going to output "infinite" amount of points (a continuous voltage changing over time) calculated from just a few points, so they are not different in that sense either. You can calculate any number of points of the circle's perimeter from the radius and center just like you can calculate any number of points of a signal using the sample points.
Dec 1, 2024 at 6:05 AM Post #92 of 182
yes you can reproduce a pure sine or sum of sinusoids as long as you're within nyquist and given there is no phase information that needs to be captured outside your sampling rate, you will have had in that case all the information between two discrete points such to reproduce a smooth curve between them.
Exactly, especially given that there is no phase information that needs to be captured outside your sampling rate!
You can think about it trivially by imagining some waveform and two samples on it, I could have a well defined curve between those two points or I could have a straight line, or for all I know or a 10000% spike in amplitude before returning back to the exact smooth amplitude I'd otherwise predict.
No, you can’t have a straight line and the amplitude is always smooth, even with a huge spike in amplitude!
Now for those things to happen I'd have to have some pretty high frequency components, which exceeded my sampling rate - but never the less they were there and you lacked the information to accurately reproduce that curve.
For the first thing to happen (a straight line) you would NOT need some “pretty high frequency components”, you’d need to break the laws of physics and so obviously “nevertheless they were there” is false! The second thing (a 10000% increase in amplitude) is well within the laws of physics, is not extremely uncommon and is well within the capability of 16/44.1, by nearly 3 orders of magnitude!
The other question to consider is what would happen if you did happen to sample or produce a sample on that amplitude spike and aliased down that higher order component.
What higher order component, why would you invent an ADC that aliased an amplitude spike and why consider a question that doesn’t exist?
In reality however the sound as it was emitted originally is unconstrained …
So you think that sound somehow magically avoids the laws of physics? The “sound as it was emitted originally” was constrained by whatever emitted the sound (what freqs it actually produced in the first place) and by wave propagation in air (EG. Air absorption of high freqs as well as roughly the inverse square law). Then, when we capture the sound, we’re constrained by the mechanical limits of a microphone plus the limits of an amplified analogue signal.
yes you can filter it in such a way that you can offer some guarantee the x frequency components have been attenuated below audibility prior to sampling but now you've of course effected the signal.
What signal? The only signal we can digitise is an analogue signal, EG. A signal that has been captured by a microphone and amplified. And that signal is effectively identical up to the Nyquist point.
From what I've read there is still ongoing research into what the minimum phase and frequency discrepancies are detectable by the human ear.
No, there isn’t. What frequencies are detectable by the human ear was settled many decades ago and detectable differences in phase was settled several decades ago.
But as an engineer who professionally works on DACs for high speed control systems I've seen the inherent distortions a DAC (or more specifically any form of discretization) always imparts on a system, and given the jury is still out on what the ear can hear, it's my 2 cents as to where the non-neutrality problem originates from.
The human ear is not a high speed control system and the “jury” is NOT “still out on what the human ear can hear”, the jury returned the verdict in the 1930’s!
[1] I guess the question for you all then is, is the thought in general that any sample rate above 44Khz is pointless?
And [2) two, what then specific to the DAC itself colors sound? or is it thought to be a complete neutral component given typical CD quality sample and bit rates
1. It’s not pointless, there are various specific applications for sample rates above 44kHz. It is pointless for audio distribution however.
2. What “specific to the DAC” audibly colours the sound is a faulty DAC design (such as a filterless NOS design) or a different output voltage but of course the latter can be neutralised by accurate volume matching. If a DAC is not audibly neutral (after volume matching), it is broken!
How are studies such as this considered then? https://www.tnt-audio.com/casse/temporal_resolution.pdf
As BS by a scientist in a completely different field who doesn’t understand how audio works and is a disgrace! His papers (related to audio) are based on audiophile myths/misunderstandings, have been throughly debunked and discredited and he is treated as a joke (albeit a pernicious one). Many questioned the utter failure of the peer review process to weed out such BS papers before they reached publication, have heavily criticised the AES (and others) and demanded the papers be withdrawn. So severe was the criticism that the AES actually responded, along the lines (if I remember correctly) that their peer review process did not fail, they are well aware that the papers are incorrect but publishing them still serves the scientific and audio engineering community because they sparked so much debate. A BS response to cover their own asses, if they know the papers are wrong they should not have been published in a scientific journal in the first place and should have been withdrawn if published in error!
G
Dec 1, 2024 at 6:29 AM Post #93 of 182
Except…
So you’re claiming analogue audio is a technology that doesn’t exist, even though it was invented nearly 170 years ago? Your assertion doesn’t make any sense, especially in light of the math proven ~75 years ago by Claude Shannon which obviates the need for infinite mathematical points anyway!
If the rate and bit depth is high enough you might hit a “limit”, despite never having met the infinite ideal.
What infinite ideal? Analogue signals cannot have an “infinite ideal” and acoustic sound even less so. If you mean “infinite ideal” in terms of the number of hypothetical points on a curve, then every DAC achieves that (with the possible exception of a filterless NOS DAC). Any analogue signal effectively has an infinite number of points and as a by definition a DAC converts to an analogue signal then by definition it creates a signal with an “infinite ideal” (hypothetical number of points).
G
Dec 1, 2024 at 6:48 AM Post #94 of 182
G
1 an analog sound in nature
2 a recording of an analog sound, fed to a DAC via finite binary code, and recreated by the DAC reading said finite binary code, to output an analog signal.
not quite the same.
Dec 1, 2024 at 7:16 AM Post #95 of 182
The voltage can be ON but the signal will move in slamm discrete steps . The DAC must work from its code, and the code in FINaiTE.
The code (digital data) is finite/discrete the analogue output isn’t. That’s the whole point of the Nyquist/Shannon Sampling Theory and how all DACs work, with the exception of filterless NOS DACs.
Continuous voltage perhaps, but the levels will be discrete …
No they won’t, the analogue output is NOT discrete levels unless the DAC is broken!
I’m claiming analog audio what..
Let’s chalk this one up to the Strawman fallacy.
I’ve no idea what you’re claiming, as I stated it makes no sense. Analogue signals effectively have “an infinite number of points along the edge” but you stated “technology does not”, therefore according to your assertions; analogue audio “technology does not” exist, unless you’re somehow exempting analogue audio from being technology! If you want to chalk that up to a strawman, fine, but then why did you make up that strawman in the first place and why are you still arguing it?
2 a recorded analog sound, fed to a DAC via finite binary code, and recreated by the DAC reading said finite binary code.
not quite the same.
Firstly, they’re not even slightly “the same” because there’s no such thing as “an analogue sound in nature”, sound is acoustic, not analogue! And secondly (yet again) the whole proven premise of digital audio is “finite binary code” from which a continuously varying analogue signal (with hypothetically infinite points) can be recreated.
So, you apparently don’t know what sound is, or analogue audio signals or even the basic proven premise of digital audio. But don’t let that stop you arguing about it on a sound science discussion forum, lol!
G
Dec 1, 2024 at 7:58 AM Post #96 of 182
I'm not sure where the disconnect is
I'm not sure I understand your argument
Not sure about this angle but I guess my comment must have made it seem like I had a "problem" with sampling?
Confusion all around :smile:
But the question is to why DACs may color sound, I'm illustrating why a DAC has an effect on sound in the first place.
Your illustrating something that you think has an effect on the sound, but given some half decent digital and analogue filtering, it doesn't. As @gregorio already mentioned, it is when you e.g. do a NOS conversion and strip out the required filtering, things go pear-shaped (and even then things aren't all that pear-shaped as NOS advocates actually seem to like that sound, apparently).
And two, what then specific to the DAC itself colors sound? or is it thought to be a complete neutral component given typical CD quality sample and bit rates
Sample rates above 44.1kHz are not pointless if you need to cover a bandwidth much above 20kHz. But these are audio DACs, not DACs used in another field of engineering that do need to reproduce signals much above 20kHz.
Re. all the disconnects implied above, and given your background and experience with DACs in a high-speed control environment; I wonder whether the disconnect is one re. end-use and real-word implementation. You say you have experience with DACs in a high-speed control environment. The whole DACs topology and transduction involved there may be quite different from those typically encountered in Audio. My father used to work in such a control engineering environment (hydraulic control of aircraft component fatigue testing rigs). Much slower in that case, but the whole control topology (incl. DACs) was optimised to account for the limited slew rates and significant levels of stiction and hysteresis encountered in hydraulic control. But e.g. no oversampling required there. In audio much of the signal discretisation and reconstruction is governed by relatively well-behaved and modelled filters and hence things like oversampling technology whilst working close to the Nyquist-Shannon bandwidth limit can be implemented quite effectively within the constrains of the limits of human hearing. The distortions you encounter in your line of high-speed control work may simply not occur in Audio DACs, or not have the same level of impact?
NOS DAC conversions and use of inferior analogue circuitry (as far as fidelity is concerned, such as tube circuitry) can definitely colour the sound of a DAC.
Dec 1, 2024 at 8:48 AM Post #97 of 182
not quite the same.
1. We're talking about recording, storing and reproducing an electrical signal. What does that have to do with "analogue sound in nature"? whatever that is.
2. You mean recording an acoustic event into an analogue electrical signal? The main point of digitisation is preserving the integrity of the analogue signal through the recording, storage/distribution and playback paths.
Dec 1, 2024 at 10:02 AM Post #98 of 182
Bzzzzt! You start right out wrong.
Sounds in nature aren’t analog, they are physical and acoustic. Analog and digital are basically encoding systems… modulation in a groove, digital samples, magnetic fluctuation on tape… none of these are natural. They’re just different ways of doing the same thing- recording sound in a format that can be reproduced.
From whatever recording medium you choose, the recorded patterns are decoded to electrical signals, which aren’t “natural” either. It isn’t until the electrical signals are converted to physical acoustic sound by the transducer that recorded sound becomes natural and physical.
Your speakers produce natural sound. The rest of your system involves encoding sound in some way or conveying it through wires as an electrical signals.
This is fundamental and even your grandmother understands the concept. The fact that you start out with such a basic error shows how you’ve twisted the meanings of words like “natural analog” to mean something those words don’t actually mean. You’re arguing semantics based on audiophile poetry, not actual scientific concepts. A little attention to critical thinking rather than argumentative fallacies would get you further.
Dec 1, 2024 at 11:53 AM Post #99 of 182
does a DA converter perfectly
reproduce the analog voltage recorded by an AD converter?
It’s a Yes or No question.
Dec 1, 2024 at 12:36 PM Post #101 of 182
You might want to google the Wikipedia page for analog recording.
Dec 1, 2024 at 12:37 PM Post #102 of 182
Yes, to a degree far beyond the range of human hearing.
And again, analog refers to the storage format, not the electrical signal. You keep using the word analog wrong.
Dec 1, 2024 at 12:37 PM Post #103 of 182
G
It's literally impossible to be more wrong.
Literally every sound in nature is analog.
Dec 1, 2024 at 12:41 PM Post #104 of 182
Sound in nature aren’t measured as quantities. Recording formats encode sound by measuring the information and representing it as measured quantities.
Look up analog recording in Wikipedia.
Dec 1, 2024 at 12:44 PM Post #105 of 182
If you expect a Y/N answer, it can only be No: you haven’t defined any condition, assumption, surrounding your question. What if the AD converter is 24 bits / 192 kHz and the DA converter is only 4 bit / 100 Hz? What does “perfect” mean? How much error is acceptable to be considered “perfect”?
