The Fourth Doctor
So I have a 2014 Sony TV that has a single multipurpose 3.5 mm analog out jack. In the menu settings for this output, you can set it for headphones, audio out, and wireless subwoofer transceiver.
Does anyone know what the difference between the headphone and audio out setting would be? Is it likely just a matter of variable vs fixed output?
I’m wondering whether or not I should plug my headphones directly into the TV (using the headphone setting) or plug my Schiit IEMagni headphone amp into the TV first (using the audio out setting).
I haven’t done enough comparisons to see if there’s real noticeable sound difference, as I can’t easily do A/B testing because I have to navigate the TV’s menu system each time I want to switch. The difference certainly isn’t as noticeable as plugging my headphones into my AVR’s headphone jack, which doesn’t sound the best.
I’m using easy to drive headphones, the AKG K371s. Basically I’m wondering if TV headphone jacks can be generally adequate, or if external amplification is preferred, even if the signal is coming out of the same jack.
Thanks!
Thanks!
