bigshot
They are referring to the mastering quality, not the format itself. Highlight the last line.
Maybe because they judge the papers by content? And that the authors are luminaries in field of signal processing/audio?To me it's an alarming sign of corruption within AES, that a "high-res marketing paper" by Meridian is chosen as "the best peer reviewed paper."
Of course that is what they are saying that. Are you not following the discussion???They are referring to the mastering quality, not the format itself. Highlight the last line.
No, no, no! That last thing you want to do is play doctor online. Instead, I suggest looking in your own signature, find JJ's presentation on this topic and try to learn that. If you did, you would see slides like this:I'm going to quote myself because it's important to look at the purposes we use digital audio for... listening to recorded music in the home. There may be some obscure situation or some specific sort of signal that a study can try to create to "break" the perfection of good old redbook. But that doesn't change the fact that for the purposes of listening to recorded music in the home, redbook is already overkill.
It takes some convoluted logic to claim that because a format is capable of reproducing super audible sound, that super audible content is important to listeners. That is a self contradiction. Instead of looking to the AES, we should be looking to audiologists and medical researchers to prove where the limits of human hearing lie.
When the standards for CDs were established, they designed the format to cover "worst case" specs. It's overkill. Music doesn't require 20-20 and it doesn't require a 16 bit noise floor. The reason they did that was to silence people from saying "perfect" wasn't "perfect enough". The problem is, people like that are never silenced. They revise the specs they consider to be "perfect" upwards further into the range of lunacy and continue complaining.
I don't care who they are. I judge people based on what the do and say. I am a person capable of critical thinking and things surrounding Meridian's MQA are most suspicious to anyone understanding digital audio. Money corrupts people everyday.Maybe because they judge the papers by content? And that the authors are luminaries in field of signal processing/audio?
I like to get the original stereo master as created. I have no need for anyone in the middle to convert it to 44.1 Kh, 16 bits or whatever including their theory of whether dither is or is not needed.
We appear to be talking past each other somewhat. I agree with Amir, 19 bits (Bob Stuart says 20) will suffice to capture the full audible range. But I agree with Bigshot too. Can anyone name any genre of music which requires anything close to that range?
Did you read what I wrote? It had nothing to do with the points you are making. Regardless, how do you know how much resolution those masters have? Do you even know how to compute that? If not, then I don't want you or anyone else in charge of truncating it to that amount. I can play the mastered format on my system thank you very much. Keep your hands away from my bits!How much of real "extra resolution" do these original masters have? Are you sure it's not just noise to give dynamic range margins? What were the noise floor values of the ADC they used? 90 dB? 100 dB? 110 dB? Yeah, 24 bits sound great, except it's probably much less real resolution and even if the extra resolution was there, how to hear it? The difference of 16 bit and 24 bit is noise at -96 dBFS or so. You really care that? Wow!
Which music? Let's see the clip names and how you determined their bit depths.Full dynamic range of human hearing is even more than "20 bits", but we don't need it, because music uses much less.
I am not seeing critical thinking when a paper that has absolutely nothing to do with MQA, is criticized on basis of its principals also inventing MQA. It is just an emotional rant that has no place in a professional discussion about the topic at hand.I don't care who they are. I judge people based on what the do and say. I am a person capable of critical thinking and things surrounding Meridian's MQA are most suspicious to anyone understanding digital audio. Money corrupts people everyday.
Sure. Fielder et al. measured the required dynamic range of different, live unamplified music and found peak range in excess of 120 dB with multiple genre including country, jazz, etc. Computation of the floor requires signal processing and psychoacoustics. I wrote a paper on this that is on ASR forum titled, "Dynamic Range: How Quiet is Quiet?"We appear to be talking past each other somewhat. I agree with Amir, 19 bits (Bob Stuart says 20) will suffice to capture the full audible range. But I agree with Bigshot too. Can anyone name any genre of music which requires anything close to that range?
