336881
- Jul 19, 2012
I've owned these for a while and like them allot. There are definitly some things to consider though. One you will need a headphone amp but it can be a cheap portable one. Two the headband pad needs to be replaced with an sennheiser hd650 headband pad. Three you need to put in a layer of dynamat extreme to get some sub-bass. And fourth you will need high quality tracks. Beatport is 320kbps and .wav. Redeyerecords.co.uk and breakbeat.co.uk have 3 options from 192kbps to .wav format if you are into techno. I personally go with 320.
