This was never in my original post... I use a variety of sources, one of those is streaming yes but bitrate is not the issue here. I'm sure some will disagree, but you can find many sources that streaming quality on a service like google play is around 320kbps on a wired connection give or take a little - so I'm not dealing with low enough bitrates (like in the 96kbps range) where the compression is legitimately the factor at play here. I also have a personal collection all encoded w/ lossless compression etc, and work w/ raw wav's in my DAW.
This clarifies things significantly vs "I'm listening to streaming music." Thanks.
For this usage, the Sennheisers would be equally competent as the Ultrasone, and offer another perspective on whatever you're working with in the DAW (they have very different tonal balances).
But yes I would like them to be used for analysis of detail and the ultrasones are pretty much the only thing I can use to get that. The JBL's are better for the overall mix - to see the forest for the trees, but the ultrasones are certainly better for the trees themselves. Especially to isolate a guitar part and to see how the effects can develop over a few measures etc.
Yes. This is generally where headphones can come into play with mixing, but I'm not sure Ultrasones would've been my first choice (despite their "Pro" marketing) - something like the HD 280 Pro or HD 600 just feels more "right" for that usage, but for listening to music, yeah I like my Ultrasones quite a bit. If I had both as options, that would be no problem either.
And yeah I'm not looking for a "mixing headphones" persay - but I'd like something that I could use to evaluate a mix, or parts of a mix. And I don't have a super large budget so I have to try and get something that does an ok job at both (like the ultrasones). I will say though that I like the JBL's presentation of the music. It seems "honest" I suppose (for lack of a better word) - the Ultrasones seem like anything will sound good on them whereas if I can get something to sound good on JBL's it will sound good on anything. (and let's be honest, the people I'm showing this music to are not going to be listening on good quality headphones or speakers)
I haven't heard the PRO750, but in my experience with the "PRO" Ultrasone headphones, they tend to be very unforgiving of shrill, harsh, aggressive, forward, etc material, as well as compressed material. Certainly not in the genre of "anything will sound good on them." That sounds more like the HFI-2400 which are very forgiving.
You will never re-create what the speakers are doing with headphones. But you can get headphones that do a good job for what you're after, and I think the HD 600 are probably the right way to go.
The EQ I have been using is okay to reduce the shrillness - I have to remember to switch it back to neutral when I'm on the speakers. Still when I was listening to glassworks earlier I noticed simply reducing gain in the highs didn't make the upper synths sound less shrill, but just less loud, but it was certainly more manageable.
Certainly an option, especially for music listening (for music listening really you can do whatever you want - its fun time, but for "work" I'd be disinclined to rely as heavily on EQ (especially if its "to taste" as you may end up masking some nastiness that's hiding in there). The nice thing with headphones is you could have 2-3 pairs and listen to the same piece on each of them, and get 2-3 different perspectives, plus what your monitors are telling you.
Maybe I'm just getting old and can't take as high of volumes as I used to when I was younger! It seems like you own some Ultrasones or at least are experienced with them - so I'll take it on good faith that it's just how they are - and maybe s-logic isn't for my ears.
I've owned the HFI-2400, PRO900, and still own the PRO2900, and I've used/heard some of the lesser PRO models (the ones they don't make anymore, that look like the Signature or Tribute headphones, but all plastic, and that weren't mega-bucks) - never the 750 though. What you're describing in terms of "everything sounds good" coupled with periodic top-end harshness is a bit "off" to me - the HFI-2400 were/are very forgiving (and they're marketed as a hi-fi/music enjoyment headphone), while the 900 and 2900 are brutally unforgiving of garbage material (but despite that, they're way too colored for monitoring imho). Maybe the 750s are trying to strike some balance in-between, I don't know. But yes, some people do hear Ultrasone as very harsh or bright, and its related to S-LOGIC (there's also a more recent phenomenon of just bashing the heck out of Ultrasone simply because they're there and some people want to make fun of products that they can't afford).
Worst part is this is a recent-ish thing for me. There's a few pro audio places in town and a lot of them have the type of headphones I'm interested in "supplementing" the ultrasones with. Pretty much all of them have the various Sennheiser model(s) so I can try them out I suppose. The DAC on my phone is a lot worse than my focusrite so I don't know how much I'll be able to discern from any in-shop trials but I could get a basis for what to expect (I'm sure if I demo whatever amp's they have in the shops I will also get a bad representation of what to expect).
Honestly, IME, differences between DACs are pretty minimal, so that isn't what I'd be worried about. What's more potentially at issue is whether or not the phone's amplifier can drive whatever headphones you want to test, but if whatever shop will let you plug the phone into a board or an amp or something and let you try the headphones that way, that should remove a lot of that doubt.
Looks like none of those Sennheisers will be able to even be driven by my focusrite anyway
I assumed the impedance was on par w/ my Ultrasones but the HD600 is almost 10x the impedance!
So?
They're 300 ohms nominal, but they aren't horribly insensitive or anything like that - most AC-powered devices with headphone jacks/headphone amps can drive them. Impedance is not a "hard to drive-ness" metric. I would be surprised if a studio-oriented product couldn't handle higher impedance headphones either - historically a lot of studio cans ran in that 250-300 ohm range (e.g. Beyerdynamic, Sennheiser, AKG, Koss).
