Peter Pinna
- Jun 4, 2008
Andrew_WOT,
First, I respectfully disagree with you. My opinion, once again, is that the Pro 750's are slightly more detailed than the 880's. I would go so far as to say that they may be evenly matched in some aspects of detail as well as in other respects but there is no way, IMO, that the "soundstage and accuracy is a leap above" the Pro 750. If you believe that to be true, your hearing perception must be very different than mine.
I have used many other headphones under professional circumstances over a 30 year period. While it is true there are headphones I have not heard, do not assume because I prefer the Pro 750, that they are the only ones I have heard. I speak about the Pro 750's frequently because I prefer them to the others I've heard. My suggestion to you is that you also "should try" to listen more to "some other phones" and that perhaps you would be well served to listen more and attentively to the Ultrasone Pro's because maybe, hopefully, then, you could begin to appreciate what I and others appreciate about them.
(Please re-read the part of my post about "brain burn in" which possibly explains the difference in our hearing perception.)
Originally Posted by Andrew_WOT /img/forum/go_quote.gif Amped DT880 is way better than PL750, details, soundstage and accuracy is a leap above Ultrasones. Having said that, 250Ohm DT880 might be very bass shy, depending on the amplification, they never worked for me with SS amps, but it was reported that tube amp fixes that quite nicely. 600Ohm version does not have that problem, has smoother, slightly warmer signature and well articulated and authoritative bass. Overall sounds juicier than 250Ohm counterpart which could feel dry sometimes. To Peter Pinna, you really should try some other phones. |
Andrew_WOT,
