Hi fernando.
First of all, be careful with response measurements. It is much more complicated with headphones than speakers. The coupling device (head, dummy head, coupler) the test method, mic location, and correction curve will all make a huge difference. Also beware that the Ultrasone curves have different scales (5db/div on one and 10 db/div on the other).
I would not choose between the 650 and 700 based on those curves. You may have to actually listen to them
Just for grins I pressed my reconfigured in-ear mic into service. This trace is without cal, and there some errors that I still have to check for. You have been warned.
Green is the HFI650, purple is the Sen HD600. I used no eq or mic correction, so these are at ear response. If I did a correction for diffuse field it would tilt the curve down to the right. Curves are unsmoothed. A bit jagged because I only took 100 samples. Oops. I do these with my glasses off, so I thought I had 1000 in the box.
I tend to ignore details above 2000 hz for now, other than general level.
Initial conclusions:
Holy crap the Ultrasones have a lot of bass energy! I suspect a resonator at work, but I will have to wait until this weekend to check. The Sens win with that liquid midrange. The Ultras don't step of the treble cliff as quickly as the Sens. All of this is obvious from a quick listen, of course, but it is fun to have a picture isn't it.
Nighty night.
gerG
