taylor
- Feb 6, 2004
The Miata does not have much headroom either. I was at the Philly auto show last year, and got to sit in the Miata. I'm 6'2", and I was very happy that the convertable top was open because if it wasn't, there was no way I was going to fit in the car. When I got in, the top bar of the windshield was at eye level.
The Miata is probably out if you're above 6'.
Originally Posted by wallijonn I STRONGLY suggest that you take it out for a 1 hour test drive. You may find the bucket seats are not the most comfortable for long distance driving. The newer seats are higher than my '90 seats. I once drove 14 hours between Dallas, TX and Phoneix, AZ. I had to take a 15 to 30 minute break every hour. I padded the seat with 1" of foam - otherwise it is murder on my back. I'm 5'7". If you're over 6' you may have problems. The Miata seats are very narrow. I wish I could put the Honda Del-Sol seats in my Miata. You can shoe horn a V8 into the Miata for about $8000 out the door. I'd rather go that way than turbo this, muffler that, brakes the other thing. When my 1.6 goes I'll be putting in a V8. |
