Toddathan
- Mar 4, 2002
I live in an older apartment building with only two-prong electrical outlets. Most of my audio and home theater equipment has three-prong plugs. I can use two-prong adapters on these plugs, but what effect, if any, does using such an adapter have on the sound/operation of my equipment? Do I risk damaging my equipment; will it degrade the sound at all? I'm also considering buying some high quality power line conditioners/surge protectors. How well will these work using two-prong adapters on the plugs of the power conditioners?
I've talked to the building management about installing some high quality three-prong receptacles for me (hospital grade or the PS Audio Power Port), but they've indicated that it will cost a few hundred dollars per outlet to properly run the ground wires.
I would appreciate any comments, suggestions, insights anyone has on this. I'm a little ignorant on some this stuff. Thanks.
