Aug 10, 2014 at 1:54 AM Thread Starter Post #1 of 3 AKang New Head-Fier Joined Jan 16, 2013 Posts 19 Likes 0 What are the best IEM's under or around $30, with an emphasis on isolation? Thanks
Aug 10, 2014 at 2:52 AM Post #2 of 3 bobby12 500+ Head-Fier Joined Apr 9, 2014 Posts 774 Likes 47 akang said: What are the best IEM's in the $0-$30 range and the $30-$60, with an emphasis on isolation? Thanks Click to expand... You should be focusing more on the fit/sleeves if you're looking for isolation. They all should isolate about the same with a good fit.
Aug 11, 2014 at 12:33 AM Post #3 of 3 AKang New Head-Fier Joined Jan 16, 2013 Posts 19 Likes 0 bobby12 said: You should be focusing more on the fit/sleeves if you're looking for isolation. They all should isolate about the same with a good fit. Click to expand... Do you have any suggestions? Right now I'm looking at Xiaomi Pistons, Phillips SHE3580, Etymotic Etykids 5.
