003
- Oct 4, 2005
OK, so here's the deal. My turntable is in the absolute worst possible location regarding isolation from vibrations. It's location can not be changed. There is absolutely NO ROOM to put it ANYWHERE else. Not on a shelf, nada. This must be made clear right now. I do not want/need suggestions telling me to move it, install a shelf, etc... There is NO ROOM for a shelf to even be installed. NONE.
So please do not give me any suggestions that involve moving the turntable or anything else around it. It just can't happen (Believe me, I've thought about it, I'm not stupid). Period. With that out of the way, I will proceed.
________________________________________________
So here's the deal. The turntable is on my desk, directly on top of my computer (not literally). It is hard for me to describe and probably hard for you to visualize without a picture, so feast your eyes on my paint skills:
The desk is made of particle board and is sitting on a hard wood pine floor.
I know, this is like the absolute worst possible place to put the turntable, but it's all I have, and even this was a very tight squeeze. Less than an inch of clearance (literally) on both sides.
What can I use and/or do to reduce vibrations as much as humanly possible without breaking the bank or relocating things? I am vaguely familiar (read: I have read about their existence, and have no actual experience) with using special isolating feet for the turntable, putting thick blocks of wood under it, using special weights that go on top of a playing LP, etc.. What can I do with a maximum of $200 to spend (relying on DIY as much as possible to conserve money) to isolate the turntable as much as possible?
Many thanks for help in advance.
![uggbq7.jpg](http://img118.imageshack.us/img118/6059/uggbq7.jpg)
