GeoffW
- Mar 13, 2003
What can I say? Logic tells me one thing, but my ears tell me another
I should clarify the "detail" comment - the detail I hear is more "spatial" detail. It seems that instruments are more well-defined in the soundstage. I guess that would be called better imaging.
Regarding dynamics, I think I remember reading that radio goes to 15khz, while CD goes to 20Khz. So in absolute terms, yes CD should be much better. I can't explain it. They could be (and probably are) using better recordings & equipment than I have. And some of that quality is finding it's way to my ears.
As JaZZ and others have commented, there may be euphonic distortions acting to make the sound more enjoyable, I don't know. I do notice that violins and string sections seem more "alive". They just seem to have more "guts". Maybe euphonic distortion has something to do with that.
I have a 15 year old turntable stuffed away in a closet somewhere. Maybe I'll dig it out.
Originally posted by Orpheus well.......... are you SURE that you are describing your results with the correct terms? cause i can tell you, unless if your CD player is worse than the worst that could ever be bought at wal-mart.... there is LESS measurable "detail," "dynamics," and "transients." ....but... more detail? no way. more dynamics?--hell no! ...radio is HEAVILY compressed. not even close to a CD's dynamic range. |
.......but, the phenomenon you are describing is similar to something a vinyl-lover experiences. the combination of distortion and high-frequency roll-off, smaller dynamic range, and the addition of pleasing artifacts and noise can produce something that you find better than CD sound. [/B] |
anyway... try buying a turntable. if you find your radio sounds better, it's very likely you'd like vinyl too. i'm trying to buy one myself.... seems like fun. |
