Fred_fred2004
Member of the Trade: Fred_fred2004 (Ebay Store)
- Sep 13, 2008
you're planning on a lot of desoldering the rolls I buy are about 4ft and last for a fair time
Originally Posted by Fred_fred2004 /img/forum/go_quote.gif you're planning on a lot of desoldering the rolls I buy are about 4ft and last for a fair time |
Originally Posted by nate911 /img/forum/go_quote.gif Good to know Any advice on my shopping list so far? Thanks for all the help...really appreciate it Also, I assume the 936 is better than a Hakko Dash or another simple pencil iron. I'm not sure how much I'll get into DIY but since I plan on building a Millet amp--the 936 will come in handy for it. This $200 should last me awhile for equipment I suppose |
Originally Posted by UKToecutter /img/forum/go_quote.gif Just as an aside..... Unless you REALLY need to keep the desoldered component, I find it much easier to clear the hole if I cut the component off the board first. That way you're only heating the remaining bit of leg. Using this method a solder sucker usually works great for me. |
Originally Posted by regal /img/forum/go_quote.gif The Hako 936 was one of the best DIY tools I bought, definately worth it. For tips you can get a bag of various sizes off ebay for $10 if I remember right. But if you only plan on building a couple amps those 15W radioshack irons will get you by, I built a Millet + diamond buffer (SMD resisitors) with one. Didn't get the Hakko until I had to solder an SMD PCM1704. |
Originally Posted by Juaquin /img/forum/go_quote.gif You're going to want more than a standard pencil iron for a Bantam. If you don't want to shell out the cash for the Hakko, there are many clones available for ~$40 that are 97% as good as the original. I use one and have been really impressed, especially with SMD soldering. |
Originally Posted by nate911 /img/forum/go_quote.gif Alright. I've looked at some like this before...but the quality concerns me. I may just end shelling out $80 for the 936... |
Originally Posted by UKToecutter /img/forum/go_quote.gif Nate. One other thing I find absolutely essential is a good light source. Probably because I'm getting on a bit and my mince pies arn't what they used to be, but good light is a must. Doesn't have to be anything fancy. I just use a desk lamp with a 20W low energy bulb (equivalent to about 75W incandescent). |
Originally Posted by Oberst Oswald /img/forum/go_quote.gif From one rookie to another... get the real 936. It will make dealing with all the small & large parts a pleasure. These DIY amps are like Wise potato chips... bet you can't eat (build) just one so it will be a good investment. |
Originally Posted by MikeW /img/forum/go_quote.gif I was at the electronics store today and found a neat little tool that i've never seen before. I have not had the chance to use it yet, but it looks like it's going to be pretty awsome. it's called a "Small parts puller" basically it's a small spring loaded plunger with a tiny "Claw" that comes out the other end, when you release the plunger the "Claw" retracts grabbing whatever is in it's grasp. I can see ton's of uses for this thing. Like holding resistors while you solder them in, or even pulling them out etc. edit: the tool is actually called "Wireprong Holder" http://www.electronics123.com/s.nl/it.A/id.2012/.f |
Originally Posted by Juaquin /img/forum/go_quote.gif I have the 2A from CSI (the digital version of the one you linked). I've used it to build two Carrie amps, my SSMH, a Bantam, and soon a Grub (in addition to other electronics projects, cables, etc). No problems so far. Quality doesn't seem to be an issue, but it can't hurt to buy the real thing either. |
