Malakei
- Jan 17, 2007
Hi there guys, i recently purchased a set of UE SuperFi's only to find the medium tips they come with dont fit me well at all. I would like to think the triflanges work best as an overall tip but i dont know since i havent used them before. That being said, will the triflanges from ety fit on a UE product? or does UE make triflanges?
Id like to know asap as i bought these to use in the gym and i need themfitting properly.
cheers
justin
cheers
justin
