TRI TK-2 Dual 9038Q2M DACs Headphone Amplifier
Product Parameters / Specifications
1. Brand: TRI
2. Model: TK2
3. Color: Black
4. The highest supported format: hard decode 384K 32bit/DSD256(Native)
5. Decoding: Dual ESS 9038Q2M
6.Output amplification type: Class A and B (Class AB)
7.THD+N distortion degree: 0.005% (1K, dsd128)
8. Frequency response range: 10-40khz (<1db)
9.Maximum output power: 1250mw (32Ω)
10. Support headset impedance: 8-600Ω
11. Jack support: 3.5mm Stereo/4.4mm balanced/2.5mm balanced
12. Fixed level LO: 2v
13. Battery life: about 9 hours (battery 5000mAh)
14. Charging interface: TYPE-C [supports QC3.0 or PD fast charging (can be used while charging)]
15. Decoding interface: TYPE-C (OTG cable is required to connect to the mobile phone)
16. Volume: about 13cm*6.8cm*2.4cm
17. Weight: about 280g
Alot more pictures on aliexpress,
https://www.aliexpress.com/item/1005003445552473.html
1. Brand: TRI
2. Model: TK2
3. Color: Black
