8140david
- Jan 30, 2007
My current set-up is this:
- A Dell laptop with USB output (also firewire, esata, RJ45, mini-jack), which I use as my source. The music is flac files recorded from CDs (16 bits 44.1 khz).
- A Musical Fidelity USB V-DAC with RCA output
- A main amplifier & loudspeakers.
Could I do better using a higher-end DAC? Which ones (under 1000$)?
Concerning which DAC to use, I seem a little limited by the outputs of my laptop.
So would it be good to use a product like the Trends Audio UD-10.1 USB Audio Converter?
TrendsAudio
It has usb input and several outputs:
- Optical connector:TOSLINK
- Coaxial(RCA) connector:75 ohms
- Coaxial(BNC) connector:75 ohms
- AES/EBU(XLR) connector:110 ohms
The idea is that using this device I could connect a better DAC to my laptop. Is that correct?
Any advice appreciated, thanks!
TrendsAudio
