New TA-10.2 , in stock new HERE
TRENDS POWER AMP, use in conjunction with a TRENDS PA-10 Tube Headphone/ Pre Amp!!
Specifications TA-10.2P
[size=xx-small]
Spec. (Amplifier Unit):
T-Amp ICTripath TA2024
Output Power2 x 15W @ 4ohm
2 x 10W @ 8ohm
Signal-to-Noise Ratio (SNR)98dB
Dynamic Range98dB
IHF-IM Distortion0.10% @ 1W, 4ohm
THD+Noise"Audiophile" Quality
0.03% @ 9W, 4ohm
0.1% @ 11W 4ohm
0.1% @ 6W 8ohm
High Power
10% @ 15W 4ohm
10% @ 10W 8ohm
Power Efficiency81% @ 15W, 4ohm
90% @ 10W, 8ohm
InputAudio IN RCA (Left/Right) x 1
Power socket (5.5mm/2.1mm) x 1
OutputSpeaker OUT (Left) x 1 pair (+ / -)
Speaker OUT (Right) x 1 pair (+ / -)
Other Switch & KnobPower ON/OFF switch x 1
Power Indicator (Blue LED) x 1
Volume knob x 1
Power SupplyDC 12V~13.2V(max.)
Dimensions(W)76mm x (H)46mm x (D)114mm[case only]/150mm[incl. sockets & knob]
Weight500g[/size]
With better power supply as well
[size=xx-small]Spec. (AC Adaptor for Special Edition):
AC InputUniversal AC 100V-240V / 50~60Hz
DC OutputDC 12V / 4A (48W)
Ripple & Noise<=50mV
Over-load Protection105%-150%
Over-voltage Protection115%-150%
Dimensions(L)120mm x (W)58mm x (H)38mm
Weight400g [/size]
TA-10.2P SE version, better audio cap - “Trends” MKP , Better power cap - Rubycon MCZ series also comes with a beefier 48W PS - $199
[size=xx-small]
2 x 10W @ 8ohm
Dynamic Range98dB
0.03% @ 9W, 4ohm
0.1% @ 11W 4ohm
0.1% @ 6W 8ohm
High Power
10% @ 15W 4ohm
10% @ 10W 8ohm
90% @ 10W, 8ohm
Volume knob x 1
Weight500g[/size]
Weight400g [/size]
Campfire Audio - Nicely Done.
Stay updated on Campfire Audio at their sponsor profile on Head-Fi.
