xmokshax
- Jun 13, 2007
i just put together a TREAD from one of Tangent's kits, and i'm having a couple of problems. i'm using the circuit with a Jameco wall wart, 24VDC 500mA. the transformer puts out 28.9V unloaded; i'm getting 26.5VDC from TP1 to TP3, and 25.1VDC from TP2 to TP3. fine. however, i can't seem to adjust the output voltage (a problem some others seem to have had), and i'm measuring 57.9VAC from TP1 to TP3 and 54.5VAC from TP2 to TP3. whoa!
the OP of this thread appears to have experienced the same set of problems as me, with slightly different numbers, but unfortunately, that thread was never resolved (or he never posted the solution that worked for him). i can answer a couple of the questions that were asked in that thread, to save everyone some time:
- i've checked for bridges, reflowed every joint, and cleaned the board pretty thoroughly, so none of those should hopefully be problems. pics will follow shortly - my camera's battery had enough juice to snap a couple of pictures, but it died before i could transfer them to the PC. [EDIT: pics added below.]
- my meter is on the 200VAC setting when measuring AC voltage between the test points. someone said in another thread that cheap meters sometimes switch automatically to AC mV if necessary. i don't know if that's happening, but either way, i don't think my cheap meter shouldn't be able to register the ripple that's coming through between TP2 and TP3.
- when i measure resistance between the outer pins of VSET, i get a value that maxes out at 957 ohms. i haven't checked how far down it goes, but presumably to zero. the part appears to be a 100 ohm (?) model - it has "W 102" printed on the top. tangent has said that he always sends either 1K or 2K trim pots. am i reading this wrong? either way, the output voltage doesn't change when i change VSET.
is my LM317 toasted? what else could be wrong? thanks for any help anyone can give.
pics:
top:
bottom:
pics:
top:
bottom:
