precsmo
- Dec 7, 2006
Hi all, I'm on the way building the Pimeta with Tread power supply and AMB's ε12 muting/protect circuit.
2 very simple questions, but I'm confused:
1. The ε12 should draw power from the Pimeta V+ and V- rails, does this mean I split 2 hook up wires from Tread V+ and V- out to Pimeta and ε12 V+ and V- in???
2. Also, If I prefered to use a power switch to on and off everything at once, does this mean just to hook up a switch in between 5.2/2.5mm DC jack V+ to Tread V+ in (with Pimeta '--' pads jumpered)? By doing this I will be able to switch on or off the Tread, Pimeta and ε12 at once right?
Thanks in advanced for the reply.
