Cruelhand Luke
nope. a porta pro does not "blow them out of the water" You are talking about a totally different headphone, but because they have a similar name you assume they are the same.I know. It's more/less the same. Which is cheap plastic, uncomfortable heap of plastic If I didn't had any then sure but PP blows them out of the water
an original HD681 with a simple mod of removing the paper inside the cups, some foam inside the pads and hybrid pad is a much better headphone than the Porta Pro. I've had both, and, you are mistaken....but hey, I'm only trying to shine a light on your darkness...as I said, good luck.
