lipidicman
- Jun 14, 2006
I have finally found a local UK dealer who can supply a Transit
£52.99 from Digital Village only ten minutes walk from my door!
Now a few questions for you helpful owners!
Would anyone steer me toward an EDIROL UA1-EX instead? I like the RCAs (and the volume control for headphones) However I get the impression the Transit is better supported with drivers and easier from what I read here
Can I run it from a Belkin USB2.0 tetrahub (guaranteed 12Mbp/s USB1 on each port) with/without the power supply?
When I run ASIO will I get only foobar through the transit?
I plan on using the SPDIF to go to a sony minidisc MDSJE520 as the DAC for now and onto my xcans. Anyone use a sony MD with the transit, does it lock onto the digital signal without unlocking sometimes?
I also plan to run the line out to my tivoli. Will this work whilst the digital is working?
I plan on leaving some headphones directly in the laptop for convenience (its good). Will I need to change settings in foobar to use them?
If I want to take the transit to work to drive headphones I assume control is via the system mixer?
Thanks for any answers you can provide. I am sure I will think of more questions!
