Packgrog
- Oct 20, 2006
Are there any companies out there that make optical cables in lengths shorter than 1 meter? That seems to be the shortest I can find.
Also, are there any companies out there that make optical cables with dual RIGHT ANGLE MINI connectors?
Lastly, does glass make that much of a difference in the short term, or is it only important if you're planning on using the same cable for more than a decade and expecting it to provide the same signal strength.
Basically, I'm hoping to link up my H120 to an external DAC before too much longer, and any portable DACs would have a mini connector. I would also prefer not to have a whole meter of cable to drag around when my H120 would be sitting right next to the DAC anyway.
Anyone?
-Packgrog
NP: Fredrick Thordendal's Special Defects - Sol Niger Within Version 3.33
Anyone?
-Packgrog
