Originally Posted by Neville
I have all parts relating to RSAAVEDRA and ITZBITZ, but noticed very little talk on replacing the standars RCA connectors. I know that the connectors are all soldered in, together as one big group of RCA's. Has anybody replaced them with Cardas or any other brand ? I only use this for 2 channel, so would consider removing the whold group and just adding on decent RCA connectors. Your thoughts on this ?
Last step in the Vinnie Rossi mods is to install separate cardas RCA outs, so Rossi for sure did that. Also the Swenson mods involve installing new separate RCA outs. I thought about it but didn't do that part. Guru (gsferrari) also asked me if I considered that. It might involve removing the whole group of outs as you indicate, or branching out from somewhere in the board to the new outs, having the stock ones in parallel, which didn't seem too good an idea for me. Also I still wanted the video for entering setup options, and after the mods it sounded great with the stock outs, so decided to skip that part of the mods altogether.
There are some slight differences between the 3950 and 3960. Apart from the 3960 being all plastic, the PCB parts layouts are slightly different. The Power Supply PCB has the fuse sitting right next to one of the parts that needs replacing, not a big issue. |
Some people in Audioasylum claim the stock 3960 usually sounded slightly better than the stock 3950. When modded, however, they both became the same other much better sounding animal. I got the 3950 because that's what the local Best Buy had when I went looking for them.
Speaking of the fuse, there are recommendations to replace the
stock fuse with a ceramic one, allegedly with sound improvements. I didn't read about that when placing my lattest Digi-key order, so haven't done it. But also, I really don't think a fuse replacement in the power supply can change the sound much, given the other major modifications in the power supply and the audio board.
Once I have finished adding the opamps I would be glad to take pics and upload for those that are interested. |
Yes pics are always welcome. Good luck!
