Okay, round two completed.
First round was the power supply mods, Panasonic FC on the audio board and the OPA2604. First round improved the bass but the high-end was still a bit grainy. Midrange was much improved in terms of overall tonality.
Second round was the black gates in the recommended spots, plus I replaced 904 and 905 with Panasonic FC's as well. At the same time, I replaced the OPA2604 (yeah, already bored with it) with a pair of OPA627AU's on a BrownDog adapter (2xSO8->SO8).
Results? I have never been one to believe the "blown out of the water" hyperbole associated with these type of modifications. However, the difference is VERY noticeable, particularly in the treble band. The grain is completely gone with very clear, detailed high frequencies. Symbols are clean, detailed and not gritty or mushed into a "squishtt" sound at all. Very quick, very accurate and a serious improvement over round one.
In amplification, I can hear an audible difference between the OPA134 and the OPA627. The OPA2604 is supposed to be close to the 134, so I'm guessing the differences are comparable. The bass is rock solid, tight and not overdone. And the midrange is amazing, female vocals come through sounding oh-so-sweet. Separation sounds excellent, off-center vocals sound well focused and defined instead of just off-to-the-side.
Amplification is via my high-end PPA with stepped-attenuator and OPA627 chips into Phil's diamond buffer, so the output stage is very complimentary to the source.
Sadly, my computer isn't going to cut it as a source unless I find a comparable output stage. The Toshiba is now dead silent in the background, likely due to the OPA627 having a 110dB PSRR compared to the 70-80 of the 2604.
So yeah, don't wait, order a BrownDog and get a pair of OPA627AU, just tell Phil that Chris sent you.
