Thanks Rsaavedra, and boy does she sound sweet. There is a LOT more detail to every cd I have listened to so far. Its also very very smooth.
I cannot do a A/B comparison but from my recollection, I would put the "3968" (am I entitled to a new name??) in the class of the mid-tier Linn cd players, NAD does not even come close, neither does most Rotel players.
It is also far superior to the stock Pioneer 563 I had as well as to my 5 cd carousal Sony SACD/dvd player. So yes, I can agree that It sounds like a $500-$1000 player
I tried to upload, but limit of 25kb forced me to use a link to my website:
This is the Power PCB layout:
http://www.uniqpc.com/toshiba_3960/power-pcb-layout.JPG
1. note the location of fuse and Panasonic ECG 150uF 250V - very different location
This is the fuse and noise filter:
http://www.uniqpc.com/toshiba_3960/noise_filter.JPG
2. Too close for my liking. But you might also note that I removed the existing filters. I cannot understand how piggybacking 2 components is going to improve anything. It makes sense if it flowed from one to the other but that is not the case here.
This is another closeup of the fuse and filter:
http://www.uniqpc.com/toshiba_3960/noise_closeup.JPG
3. If I had known about the fuse tweak I would have kept the longer legs on the filter next to the fuse, but its not like I will be changing fuses often (I hope!) Look at that monster Panasonic ECG !! Its height brings it into close proximity to the DVD top case. I am going to either have to shorten the legs or place the HDepot tile on the outside of the case.
So what did I not replace ?
"Replace C825 (10V, 120uF) with Panasonic FC 16V, 220uF
[Digi-Key Part Number P11199-ND]"
Reason was Digikey did not have it in stock but I am not planning on doing it anyway if they do restock...
Future mods:
1. ceramic fuse - Rshack only had glass fuses
2. damping which I plan on doing today with JR Wels
3. "takking" the crystal - Lowes had "fun tak" which i hear is not the right one. I cannot see why AAdvisor sells Blu Tak for $10 ??? Any other places ?
4. Painting it black - all my components are black except for my Jolida 1501RC.
5. Adding el cheapo rubber feet from a previous project
6. replacing power cord with HDepot power cord
7. I have not used the video menus but will look into that - I have not found any comments if there are menu tweaks
8. Adding heatsinks chips on Audio PCB
My gut feel tells me that damping and rubber feet will make the biggest difference, obviously apart from the drastic part mods its already undergone.
