bust3r
- Feb 2, 2015
Or some other AMP/DAC combo?
I'm looking for an amp that will feed a pair of LCD-X's well, that has good dynamic range/measurements, all that stuff, etc and the DX7 Pro was mentioned/suggested as a DAC amp combo, but I'm concerned about the power. I cannot use my sound card if I want to EQ the Audeze's, the sound card SW is not compatible with APO and PEACE EQ that I need to EQ the headphones with, so I need a DAC to either pair with the A90, or look at the DX7, if it has enough power (to your opinions).
And of course open to any other suggestions as well, and I'm also reading that tube amps do not sound good with these headphones, but of course I have no idea if that is true or not.
Thanks!
Thanks!
