Has anyone with the D90 / A90 / ? fixed or substantially improved the RCA connection "noise" by shortening RCA cables or buying better shielded RCA cables? How about better shielded USB cables?, or some other method of reducing the PC noise brought in through the USB cable? If you've debugged your noise problem to root cause + solution, please let us know the details.
Before I spend $ on new RCA / USB cables or other solutions, I'd like to know if it's worth the effort. I'd like to use RCA output from the A90 to drive power speakers, but I could put the extra $ instead into better powered speakers + XLR cables.
Thanks for the suggestions, I found these premade RCA Mogami 2534 1.5 foot / 0.5 foot sets ( 4 wire) and premade RCA Mogami 2549 (2 wire) 1.0 foot as a jumper between the A90 / D90 MQA - see their Construction and Specifications images for more details:
0.5 Foot – Directional Quad High-Definition Audio Interconnect Cable Pair Custom Made by
WORLDS BEST CABLES – Using Mogami 2534 Wire and Amphenol ACPR Die-Cast, Gold Plated RCA Connectors
by WORLDS BEST CABLES
https://www.amazon.com/0-5-Foot-Directional-High-Definition-Interconnect/dp/B01ALHT7CI
1.5 Foot – Directional Quad High-Definition Audio Interconnect Cable Pair Custom Made by WORLDS BEST CABLES – Using Mogami 2534 Wire and Amphenol ACPR Die-Cast, Gold Plated RCA Connectors
https://www.amazon.com/1-5-Foot-Directional-High-Definition-Interconnect/dp/B01ALHUSYE
Mogami 2534 vs 2549 - EMI shielding vs "Sound"...?
1 Foot – Directional High-Definition Audio Interconnect Cable Pair Custom Made by WORLDS BEST CABLES – Using Mogami 2549 Wire and Amphenol ACPR Die-Cast, Gold Plated RCA Connectors
https://www.amazon.com/gp/product/B01ALFR02Y
Robert R 5.0 out of 5 stars Brand Lives Up To Its Name
Reviewed in the United States on June 23, 2020
Verified Purchase
"Very nice high quality interconnect. I did some research and the Mogami 2549 in this offering seems to be a better option vs. heavier shielded cable also offered by WBC which only improves EMI resistance. Some posts claim that the wire in this cable sounds better vs heavier shielded counterparts. At the end of the day, this is a high-quality well soldered interconnect with excellent packaging and presentation. It's serving my needs well in between my E30 DAC and 789 Amp."
The 0.5m XLR cables from SKW are working fine - no noise even at H Gain 100% volume... so for now I'll stick with those. Amazon has SKW 1.5m as the shortest length; the 0.5m length I sourced from Hifigo in China:
https://hifigo.com/products/skw-hif...ixer-amplifiers-1-pair?variant=32043150934065
https://www.aliexpress.com/item/33034630648.html
https://www.amazon.com/SKW-Balanced-Female-Microphone-2-Pack/dp/B07Q8Q16F9
