Drop the DAC output level if you can?
It's possible, if I switch to Pre mode on the D90 MQA instead of DAC mode, and modulate the drive of the D90 with it's volume control, that's a good idea!
Both the AS16 and DK2001 are loud with barely any volume set at L Gain, so that is worth a try. Plus I might get more sensitive IEM's so that would help them too.
I'll need to see how that affects my current power hungry headphones and IEM's, but until I get DT880 / DT990 600 ohm headphones that are supposed to take 50%-75% power on H Gain I probably don't need to worry about it now.
I also just received the RCA cables to connect the D90 / A90, I'll see how the volume is on RCA connected mode too, perhaps that is an option?
Thanks for reminding me about the D90 MQA Pre mode, which I haven't tried that as a solution yet!
It's fixed output in a DAC mode.
With that being said, why use sensitive IEMs with a powerful amp???
You're not gaining anything.
I use sensitive IEMs to test noise sometimes but don't understand using IEMs with desktop HP amps.
The range of the A90 should be enough for me to use all of my headphones / IEM's, all I need to do is to find out how to configure the D90 / A90 to support their full range.
The A90 has 3 positions for Gain - L/M/H, and I think that was intended to support a full range of IEM's / headphones out there.
Both the AS16 and DK2001 sound amazing on the A90, it's only that I have such a small volume control range to enjoy them right now.
Update: A couple of updates. Indeed the DK2001 / AS16 have more volume range with the RCA only connection between the D90 => A90 in L Gain - sounds great and it was nice to be able to have more adjustment for the volume.
Unfortunately my A90 also exhibit's the "noise" with an RCA wired connection. In H Gain - even with Zero Volume - in M Gain from 50% onward - in L Gain the noise is there compared to an XLR only connection, so I can't use the RCA connection as a solution.
I'm back on XLR only - I had to physically remove the RCA cable between the D90 => A90 to stop the "noise" - and the D90 is now in PRE mode with the D90 volume set to -12.0dB.
I now I have enough range on the volume control on the A90 for the DK2001 / AS16 - and XLR only sounds better - a darker background in silent areas in L Gain than with RCA in L Gain.
I'll check the power hungry headphones later and see if I need to increase the output from the D90 to the A90 via the D90 Pre.
