DesBen
- Aug 6, 2001
Hello all, I haven't posted in over a year I think. Consider this my return
At home, I still prefer to listen to my stereo (with tube amps!), but at work, headphones are the only way.
I'm hoping you guys can help me out with a little problem of mine. I'm looking for a new set of cans to use at work. Sound leakage is a problem so I need closed headphones. I currently use Sony V6. They aren't bad, but their limitations are evident. They lack refinement in my opinion. They could be more open in the midrange, more textured in the bass, sparkly on the treble, etc. I need something more fluid and musical, less "electronic". I want breathy female vocals to sound sweet and sensual, not analytic.
I recently heard the AKG K501. I really liked what I heard, but they leak way too much sound. Are there any closed AKG that sound similar? What about Beyer?
I listen mostly to jazz and electronica. I have an MG Head OTL so high-impedance cans (>100 Ohm) are OK, and actually preferred. I'd like to keep it under $300.
