To what extent will good headphones improve sound quality at an MP3 level
post-2406230
Thread Starter
Post #1 of 22
Pwntendo
Well I was thinking of getting some beyerdynamic DT990's for christmas.
This would be the first time I've bought any sort of top range headphone.
And the reason I was attracted to the DT990's was because I've read they are the most comfortable headphones you can get, and are great for long listening sessions.
Now the problem I have is that I'll be playing them from an iPod mini which will obviously be playing in MP3 format, and all my songs have been downloaded from soulseek and whatnot, so they will have bitrates from 192 fluctuating upwards. Is this good enough quality for such a good pair of headphones, or should I go for something a little less good.
Also, the PC I'm using right now has an X-Fi Xtrememusic soundcard, so if I were to connect the DT990's to that, and play the same MP3's would there be alot of difference?
And also
Would getting an amp solve the problem?
post-2406243
Post #2 of 22
ap3rtis
i've been listening to some low bitrate mp3's just out of my laptop's soundcard (which is likely trash) with my dt990's and it doesn't sound bad at all. I'm sure the sound isn't really optimal, but it's not terrible by any means.
post-2406245
Post #4 of 22
amartignano
Italy - Knife Edge in other forums in the world
The DT990 is very revelatory with sources, amps and interconnects. I think it's an headphone to treat with "high-end" setup to have the best from it (it's likely you will hear clearly the limits of the mp3 with those headphone... but it is at the same time likely you will like anyway such a "funny" sounding headphone).
So... 2 options
a) get a less revelatory headphone (wallet happy, ears happy but less happy than option (b) )
b) get the Dt990 and risk to feel soon "source upgradity" urgence (wallet cries, but ears will be very happy at the "end" of the process)
bye
Andrew
Ps. oh, yes, they are VERY comfortable
Pps. at least, DON'T GO UNDER 192 kbs in bitrate, DT990 will reveal all artifacts
post-2406252
Post #5 of 22
Pwntendo
Also I heard they are good for Electronic music, Trance, IDM, Chillout, Ambient etc.?
post-2406263
Post #6 of 22
errorrrr
I consider low bit-rate =<128kbps. At about 192kbps+ on mp3, the difference is very subtle, almost unnoticeable to me... but some Audio guru probably have different opinion... and I am interested to know which level of mp3 compression is best of the 2 world size/sound.
post-2406264
Post #7 of 22
amartignano
... classical, jazz, rock... etc etc...
they are a good allrounder
post-2406274
Post #8 of 22
Pwntendo
Oh..
Also, would an amp cure the problem of having lowish bitrate (192) MP3's?
post-2406278
Post #9 of 22
ap3rtis
I'm pretty sure they would sound good with anything. As for some of the lowrate mp3s I've listened to a handful of 128's, 192's etc, and it sounds fine. I do plan on getting an amp at some point, but they do sound pretty good just out of the laptop.
post-2406280
Post #10 of 22
amartignano
You don't need to be a guru to hear difference between Mp3 and CD, you need only your ears. Listen especially to transients (on acoustic and classical guitars for example, on cymbals...).
Anyway, I consider Mp3 a geniality for portable music, good sound quality on the road. But for home use, given PC + Sound Blaster as a source, the best should be lossless compression.
Andrew
post-2406286
Post #11 of 22
amartignano
Oh..
It's likely an amp will increase the problem getting more resolution.
Anyway, you can "begin" with the DT990 and then let your ears decide on the next step (if necessary)
post-2406302
Post #12 of 22
glac1er
Hi, welcome to head-Fi and sorry for your wallet
I used to own the old DT990 and extensively used them with Ipod and 192kbps mp3. In my experience, even with those kind of mp3s, I am still pleased with the increase of listening enjoyment when I moved from MS1 to DT990 and when I moved from DT990 to HD650. Using mp3 should not hinder you from buying more expensive headphones IMO.
It's a little bit different with amps tho. An amp will definitely increase sound quality if you use mp3s; however, with lossless files or CD, the change is more dramatic. If you plan on buying an amp, you should really start using lossless files or CDs.
post-2406368
Post #13 of 22
errorrrr
Andrew
hm... i don't quiet undertsand :/ I never really noticed... I guess I really havn't listend to too much CDs lol... I dont' usually listen to off-vocal rocks... lol all have vocals so I don't notice too much XD
post-2406417
Post #14 of 22
werdwerdus
From what I've heard and read, the Ipod Mini has the worst sound quality of any of the ipods. You might want to consider getting a nano or a newer full-size ipod. That would probably help more than higher bitrates.
post-2406539
Post #15 of 22
regal
I can't even listen to 192kbs cbr MP3's. The voices sound like their singing in a wind tunnel.
