Originally Posted by BobMcN /img/forum/go_quote.gif
I don't think any engineer would argue that different metals conduct electricity differently,
Actually, no, all metals (conductors, if you will), conduct electricity exactly the same. Specific conductance (measured in siemens per meter) does vary between materials, but other than that, all conductors conduct electricity the same way. This is a more fundamental point than you seem to understand.
- or that guage plays a role
- or that solid vs stranded construction plays a role
- or that different dielectrics interact to influence the inductance and capacitance and resistance
- or that shielding influences the signal
- or that different geometries affect inductance and capacitance and resistance
These all do play a role in setting various parameters of the cable. It is rather unlikely (but possible) that unknown parameters exist. The effect of any such parameters would need to be rather limited however, given existing measurements. In another thread I presented the theoretical maximum differences between an ideal cable of no effect on the signal at all and a very very bad cable ... You should look it up, and consider what the magnitude of the difference implies.
So why is it so hard to think that different cables can affect the sound differently, unless of course they are constructed identically?
Sure, an engineer will also say that regardless of the construction, if they measure identically (within audible tolerances per his/her textbook of electrical properties) there should be no difference. To that I answer, what if even you can hear a difference ... will you still believe that there is none because the textbook says there shouldn't be? (to which he will say he was influenced by the color of the cable or some other such thing, no doubt.)
Now a theoretical scientist might postulate that we don't have adequate tools to measure this properly. Sure, we now believe in quantum particles, but we still can't see them. We can only measure them indirectly and draw conclusions based on indirect measurements that are based on theories, whcih may be proven inexact over time. So perhaps the perceived differences in cables need to be understood and measured indirectly, based on an assumption that there is something here that is not clearly understood.
It is not just what some textbook says is or is not different, it is what can be rather easily computed to be essentially no different and also measured to be no different. Worse, it is far below the threshold of thermal noise for common cable lengths. Which is besides the point to what would have happened to the sound in the recording studio passing through rather ordinary cables.
While theories may be proven inexact over time, there are very well established minimum thresholds to the inexactness, much like for special or general relativity. A future theory cannot disprove the already existing measurements as to what a cable does / did not do to a 20KHz signal. If you can describe the effect some cable supposedly has on the quality of sound closely enough, a model can be built based on that and used to check whetever such effects actually exist (or not).
Something rather indicative that differences claimed to exist by "cable believers" don't, is that the
specialty audio cables have exactly the same construction regardless of length. For a cable to have exactly the same effect in both a 0.5 m length and 2m length, some combination of its parameters would need to have a 4x difference. This however does not appear to be the case.
