Hybrim
- May 16, 2014
Hi, after having only used those standard samsung J5 headphones that came with my galaxy note 3 phone (unrooted), I've finally bought my first expensive IEM in hopes to spoil myself - the Sennheiser IE80, from an authorized dealer for $320. But after these first days of burn-in I must say I'm kind of torn whether they are even worth the high price.
On the first listen I immediately heard the bigger soundstage which I ofcourse like but I'm pretty dissapointed with the lack of bass (even tuned to the highest and I can't hear any difference) but perhaps this can be fixed with a better seal. But then there's the worst thing that's a deal breaker for me, I've started to hear a white/static noise on every calm track, especially on orchestral music, which I'm hoping you other users can help me solve whether these are infact defected or not. I just can't listen to any of my soundtracks with this noise, so if this can't be fixed then I'm forced to return these headphones.
I'm not an audiophile so perhaps I've missed something, but here are some of my thoughts and questions:
1. All my tracks are mostly 320kbps mp3s and some flac, so it's not that the files lack quality or anything.
2. Are expensive IEMs really so clear that you can hear the white noise even more compared to cheaper IEMS? Before these headphones I never realised the noise on my cheaper ones.
3. The white noise is heard no matter what source I use: galaxy note 3 (stock/winamp/google players), my PC, my brother's PC and his iphone.
4. The bass is good if I put pressure on the earbuds to my eardrums, but without that pressure they sound too distant. (even tuned to highest and still can't hear any bass difference)
5. The isolation sucks because when cars drive by I can't hear the music on highest volume, even with finger pressure,
6. After having tried all tips, I settled with the normal sized tips that the IEMs already came installed with.
7. I'm not 100% sure yet, but the noise seems to be increased the higher the bass is tuned, although the noise is still a problem at lowest tuning.
8. Perhaps the noise is a sign of defect? Or cord related?
9. Perhaps these are even fake? I bought them from an authorized seller, but the package didn't come with a QR code so I can't really check the product's authenticity on sennheiser's website.
I can post pictures of the package and the headphones if so needed. Thanks!
