Originally Posted by greggf /img/forum/go_quote.gif
Wow. Great thread.
What Head-Fi is all about is, unfortunately, something known as "response bombardment," an idea put forth by a French psychologist named Pierre Turquet.
"Response bombardment" is what happens in large groups - and Head-Fi is now large and busy - when there are "too many responses, from too many people," of radically-differing quality or reliability.
"Too much stimuli of too low quality" is a trademark of large internet forums of any kind, and a hallmark of response bombardment.
When this happens, it's hard to glean good info from bad. It also ruins the credibility of forums - hence the new headphone forums that are sprouting up, often populated by the best & the brightest veterans of the older forums.
Tim is responding to that with his frustration. Boomana is also responding to this frustration from another direction, trying to, as Turquet says, "prevent response bombardment from overwhelming the selves of the members" (of the group - Head-Fi, in this case).
The repeats of these threads, of Tim's repeated frustrations, of boomana's need to constantly try to make her point heard over the din of the bombardment of nonsense and trivia, proves that:
It's time for the management of Head-Fi to look into ways of ordering the information available here in the site, in a way that takes advantage of "wise elders" such as boomana (I have no idea how old you are, but you certainly are wise!), and accommodates the needs of noobs like the o.p.
As it stands right now, Head-Fi is a cheap gear shi**ing machine, pumping out lots and lots of FOTM and portable stuff designed more to frustrate would-be hobbyists (and fatten the coffers of the same-old same-old vendors) rather than get them addicted and fat and happy.
Great post.
I don't think that Head-fi needs to change in any way. To my mind I see head-fi in the same light as any other information source - there are conflicting and competing views that the consumer needs to wade through and assess 'in their own context'.
Example:
If you want to buy a can of cola, but had never had previous exposure to a cola drink, what would you buy? Probably based on advertising and market hype, either coke or pepsi. What if you chose pepsi and didn't like it? Would you never buy another cola drink, or complain that the information you had was misleading? No. Reality is that you would probably try different brands until you found one you liked; after all, at $2 a can you can afford to try a few different ones until you find something you like. That is the key. It is a cheap enough product for you to explore options for yourself without needing objective criteria or 'accepted truths' to support your initial decision.
What about a higher $ cost purchase such as a car? Would you buy an
Ariel Atom as you family car? Most likely not. Why not? Clearly, because you can apply objective criteria to the purchase and determine that it will not meet your needs. Would you buy one and then complain that you can't fit a child's booster seat?
We often make these objective assessments without necessarily realising - the requirements and constraints are often all very obvious.
However, it all gets a bit harder when it comes to a purchase for which there are some objective criteria and some less obvious criteria, while satisfaction with the purchase will be primarily based on a subjective assessment. Headphone amps fit into this category. The simple (and easy) objective criteria relates to whether you want to be able to carry the amp with you or not; eg. portable and battery powered. The less obvious (requires a bit more research) criteria will include whether your headphones will actually benefit from more power,and whether the amp has enough power to drive them. These tend to be the fuzzy information that are difficult to quantify, measure and justify, but they are usually supported by the community and may be considered 'accepted truths'.
Finally, the absolutely subjective criteria of whether there is 'synergy' between the amp in question and the headphones you wish to drive, and whether you will like the 'sound' of the amp.
It strikes me that there are more than a few head-fiers (new and not), who may assess the more objective criteria appropriately in their own context, but ignore or don't research enough to find the 'accepted truths'. They buy the wrong amp, and then, when it comes to their own subjective assessment, the results are poor.
Unfortunately, in audio there are very few objective criteria, and only a few 'accepted truths'; most of the assessment is subjective and relates to detail that the majority of the population would never care to discerne.
Sometimes, you will still 'underwhelmed' with your new purchase, regardless of the amount of research you do - such is the audio journey.
