I have rather small ear canals, and the tips that come with the triple.fi 10s relaly don't fit very well... The best I've been able to do is reverse the headphones and use the foamies, but the UE foamies are pretty uncomfortable. Has anyone had any luck with finding other tips that fit and don't totally screw up the sound? I really wish Comply made foamies that fit these phones -- I'd love to see how they sound with some decent isolation.
Tips for triple.fi 10 pro phones?
- Thread starter Trager
sonic32
I dont think the design really isolates like you might hope. They will never compare to the Ety ER-4 in this way imo. The benefit to this design is the relative ease with which you can insert/remove them. I just received mine a few days ago, so still just playing with them, trying to find the best tip myself. Can't really help you with the tips, sorry.
YoungClayB
- Aug 17, 2005
The grey tips from UE seal much better than the black tips that come with the triple.fi's. The grey tips are softer and just seal better for some reason.
Call UE and tell them that you can't get a seal...I'll bet they will send you some soft grey tips for free. UE customer service is great when it comes to things like this.
Actually, I did do that, and I have two bags of the grey tips now. I just didn't find them that comfortable, and I just couldn't get over hte midrange recession. It just wasn't worth keeping them, comparing the sound to my ER-4P phones and considering the price.
Spyro
- Apr 15, 2003
I guess the fit is a trade-off. I find the Etys an absolute pain in the a** fit wise unless you stay still.
Triple Fi 10 Users: Do they leak sound at high volumes enough to annoy someone next to you?
I am getting ready to pull the trigger on a pair. While I have heard a couple posters say the midrange is recessed, most of the reviews I read say they are light years better than Super Fi Pro. If that's the case they must be fantastic!!!
cindyk
- Feb 7, 2007
I got Super.fi 5 pro, I use custom made foamies(EARSOFT) which I can also recommend, it is a very cheap and yet effective option. Isolation is superb and so is comfort.
toomtaam
- Mar 11, 2007
Where you get those from ?
Originally Posted by cindyk /img/forum/go_quote.gif I got Super.fi 5 pro, I use custom made foamies(EARSOFT) which I can also recommend, it is a very cheap and yet effective option. Isolation is superb and so is comfort. |
Bones13
Sell your triple.fi and get some customs. Best move I have made in this business. I tried all the tips with my Shures and Etys. I could get a seal, but they would become uncomfortable in half an hour or constantly need reseating.
cindyk
- Feb 7, 2007
Drugstore, you can also get them at earplugstore.com. You can have them in for hours and your ears won't feel any discomfort.
Originally Posted by toomtaam /img/forum/go_quote.gif Where you get those from ? |
Definitely agree with this one. I used to get a great seal with my e500's and they were quite comfortable too. But, I found myself constantly adjusting them and taking them out every hour or two to give my ears a break. With customs, you just "set it, and forget it" (I know, that's really bad).
With the FS mod, I found the fit and comfort much, much better, but I could never get a really great seal. Not sure why?
Originally Posted by Bones13 /img/forum/go_quote.gif Sell your triple.fi and get some customs. Best move I have made in this business. I tried all the tips with my Shures and Etys. I could get a seal, but they would become uncomfortable in half an hour or constantly need reseating. |
cyberspyder
Caution! Incomplete trades.
- Mar 2, 2007
I've gotten the best(?) possible seal with the black ultra soft flex sleeves from Shure.
Originally Posted by rlanger /img/forum/go_quote.gif Definitely agree with this one. I used to get a great seal with my e500's and they were quite comfortable too. But, I found myself constantly adjusting them and taking them out every hour or two to give my ears a break. With customs, you just "set it, and forget it" (I know, that's really bad). With the FS mod, I found the fit and comfort much, much better, but I could never get a really great seal. Not sure why? |
Spyro
- Apr 15, 2003
Are Triple Fi Pro's physically the exact same size as the Super Fi pro (use same housing case) so fit will be same?
YoungClayB
- Aug 17, 2005
The snouts are the same size. The driver housing of the triple.fis is slightly larger than the super.fis, but not very much at all.
Originally Posted by Spyro /img/forum/go_quote.gif Are Triple Fi Pro's physically the exact same size as the Super Fi pro (use same housing case) so fit will be same? |
mrdeadfolx
- Jan 18, 2007
http://www.ultimateears.com/videos/superfi_mod.htm try this, it seems to solve seal problems for many.
cindyk
- Feb 7, 2007
You can achieve that with custom foamies too
Originally Posted by rlanger /img/forum/go_quote.gif With customs, you just "set it, and forget it" (I know, that's really bad). |
