MikeW
- Nov 4, 2005
The PS Audio Power Port is 49.95 at their website. Not much savings I know, but every penny counts! There's another one called "Porter Port" for 36$
Originally Posted by TheSloth Sorry Mike! To be honest, I do think there was some specific issue in my set up, but I'm not the kind of guy who wants to sit there re-arranging the order in which his equipment is plugged in to get round a component that doesn't sound good. I like things as simpe as possible, and as such have removed all my power conditioning completely. The only kind of power conditioning that makes sense to me is AC regeneration, as in the higher end PS Audio stuff. I might give that a try at some point. |
Originally Posted by DarkAngel AC regenration unit has many disadvantages also: - higher cost |
Originally Posted by DarkAngel -takes up much more room |
Originally Posted by DarkAngel -doubles power comsumption of audio system, higher electrical bills |
Originally Posted by DarkAngel -fans are noisy |
Originally Posted by DarkAngel -gives off heat |
Originally Posted by DarkAngel -restricts dynamics of large power amps |
Originally Posted by DarkAngel AC regenration unit has many disadvantages also: - higher cost -takes up much more room -doubles power comsumption of audio system, higher electrical bills -fans are noisy -gives off heat -much more complicated design -restricts dynamics of large power amps BTW I much prefer the passive PSA UPC200 to Ultimate Outlets |
Originally Posted by TheSloth Those may be disadvantages indeed, but none of them are sonic disadvantages. I don't have a large power amp - the maximum possible power draw of my two powered monitors together is 240 watts, though I doubt I would ever get them anywhere near that peak output. I estimate my balanced home chews through about 25 watts. So I need about 300W delivery to be on the safe side. A used P500 would be perfect for me. I'm really not interested in the logistics, simply the SQ. Are there any potential sonic disadvantage to AC regeneration, assuming it provides enough current? |
Originally Posted by Patrick82 A PS Audio Power Port could make a bigger improvement than a UPC-200 with a bad port in the wall. |
Originally Posted by philodox I seriously doubt this is true... have you tested out your theory? |
Originally Posted by akwok Power should be the last thing you do to your system. If you expect a difference, you'll hear a difference. I didn't, so I didn't hear a difference. |
